ScottCarRock
Jul 14, 2021Aspirant
Orbi RBR750 issuing two IP Address Networks 192.168.0.1 & 192.168.1.1
Yesterday, I installed the new Orbi 4200 / RBR750 and I have been fighting intermittment internet connectivity. In viewing the connected devices I noticed the two different IP Address Networks. The...
CrimpOn
Jul 14, 2021Guru - Experienced User
ScottCarRock wrote:Yesterday, I installed the new Orbi 4200 / RBR750 and I have been fighting intermittment internet connectivity. In viewing the connected devices I noticed the two different IP Address Networks. The devices which did not have internet connections were attached to the 192.168.0.1 network.
How do I turn off the 192.168.0.1 network. In addition, I do not have a Guest Network set up. It's turned Off.
The most likely situation is that the ISP modem/router is assigning IP addresses in the 192.168.0.x subnet and the Orbi is assigning IP addresses in the 192.168.1.x subnet.
What it sounds like is the Orbi router and Orbi satellite are both connected to the ISP router (or maybe to a switch that is connected to the ISP router).
The Orbi router WAN (yellow) port is supposed to be connected directly to the ISP device and Orbi satellites should be connected to the router LAN ports (or over WiFi).
The Guest network is an option on the same menu at Attached Devices.
