tdl129
Jun 02, 2024Aspirant
Orbi RBR750 keeps disconnecting from (2) Satellites (RBS350)
In the Orbi App I recently clicked the "update firmware" for my RBR750 router, after updating it's been disconnecting from the (2) RBS350 satellites. I've tried to do resets of the satellites and al...
Jun 03, 2024Guru - Experienced User
You need to downgrade the RBR750 beck to v4 FW:
tdl129 wrote:
In the Orbi App I recently clicked the "update firmware" for my RBR750 router, after updating it's been disconnecting from the (2) RBS350 satellites. I've tried to do resets of the satellites and also did a factory reset of the entire router + satellites. I was able to get them to connect for about a day and now I can't get the satellites to connect.
RBR750 - FW V7.2.6.31_5.0.24
RBS350 - Firmware Version : V4.4.1.29
I tried looking for a more current FW for the RBS350, but I appear to be running the latest that's on the support site.
Anyone have an idea of how to fix this?
Thanks
- tdl129Jun 03, 2024Aspirant
Downgraded to v4 and that fixed the issue. I made sure to turn off auto update.
Thanks all!
- FURRYe38Jun 03, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. š”- irmcdermottJun 05, 2024Aspirant
Cannot thank you enough. I had this same issue (upon setup it auto-updated the router FW causing satellites to not connect) and have been banging my head against the wall. Downgrading the FW on the RBR750 solved the problem. Thank you again.
