boston_mama
Aug 25, 2021Guide
orbi rbr750 keeps going offline overnight
My Orbi RBR750 (model + 2 satellites) keeps going offline. It's fine at night but in the morning will be offline. I reboot it using the app and it's fine but it's going offline several times a week...
Aug 25, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
Do you see any front LED colors on the RBR or RBS when this happens?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
- boston_mamaAug 25, 2021Guide
My answers below:
It's hooked up to an xfinity gateway -
Voice and Data Modem
ARRIS Group, Inc. TG4482A
Yes
No color on the RBS. Not sure on the RBR. I'd have to look at this next time.
2500 sq feet
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.Yes
- FURRYe38Aug 25, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode- boston_mamaAug 25, 2021Guide
I tried option 3 you suggested. We will see if that works.
I tried having the modem in bridge mode but it kept coming out of bridge mode and then my wifi would go unstable. So I took it out of bridge mode and turned off wifi. I did not do the AP (step 3) step as you suggested at that time. So just added that step now.
I am curious...how do you do #2? Are there detailed instructions for this? And should I do that in addition to 3 if 3 didn't work?
Thanks!
- S1m0nGAug 25, 2021Initiate
Same problems here, the Orbi RBK750 router has a purple light when I power-cycled it this morning after it went offline overnight. Again.
ISP - Ting gigabit fiber
Satelites are hard-wired to the router
Firmware version V4.6.3.7_2.0.49 (latest)
Are the RBS connected directly to the back of the RBR or is there a LAN switch in between?
