boston_mama
Aug 25, 2021Guide
orbi rbr750 keeps going offline overnight
My Orbi RBR750 (model + 2 satellites) keeps going offline. It's fine at night but in the morning will be offline. I reboot it using the app and it's fine but it's going offline several times a week...
boston_mama
Aug 25, 2021Guide
My answers below:
It's hooked up to an xfinity gateway -
Voice and Data Modem
ARRIS Group, Inc. TG4482A
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
Yes
Do you see any front LED colors on the RBR or RBS when this happens?
No color on the RBS. Not sure on the RBR. I'd have to look at this next time.
2500 sq feet
Yes
Aug 25, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
- boston_mamaAug 25, 2021Guide
I tried option 3 you suggested. We will see if that works.
I tried having the modem in bridge mode but it kept coming out of bridge mode and then my wifi would go unstable. So I took it out of bridge mode and turned off wifi. I did not do the AP (step 3) step as you suggested at that time. So just added that step now.
I am curious...how do you do #2? Are there detailed instructions for this? And should I do that in addition to 3 if 3 didn't work?
Thanks!
- FURRYe38Aug 25, 2021Guru - Experienced User
One needs access the the modems web page. There should be a user manual for doing this and accessing any DMZ or IP-Pass thru fuction on the modem. The ISP support services will also know how to set up the DMZ or IP-Pass thru features.
The options is mostly setting the IP address the RBR gets from the modem into the modems DMZ or IP-Pass thru for this option. So that there is less routing problems between the modem and RBR when you have two routers on the same line.
Keep us posted...
FURRYe38 : My modem has wireless turned off, my Orbi is now in AP mode per your suggestion. Everything is working for now (will see if it still works in the morning),but I have a question on something. I have multiple devices hooked up to the Orbi router (per the app), but noticed I was missing quite a number of other devices too. I looked up what's connected to my modem and it shows 10+ devices connected there. How is that possible if I have wireless turned off? Will this be an issue to have devices connected to both my modem and my router?
