Red5694
Aug 16, 2023Follower
Orbi RBR750 not allowing podcast
I am having an issue with my Orbi RBR750 not allowing Apple podcasts to play on wifi. It is also blocking a certain website from loading. If I go to cell data on my phone everything works fine b...
Aug 16, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected
Be sure to disable any MAC Address randomizers while at home:
Armor, Smart Parental Controls or Circle, Traffic Meter.
