mbaltimore
Dec 07, 2021Initiate
Orbi RBR750 not allowing Samsung TV to connect to the internet.
HI...I have an ORBIT RBR750 with two satellites. For some reason, my Samsung TV is not being allowed to connect to the internet through the Orbi Satellite. The error message says it can't set the I...
- Dec 07, 2021
mbaltimore wrote:With resepct to your last comments, sorry I am just not technical enough to know how to answer them.
The problem is almost certainly not because of 2.4Ghz vs. 5Ghz, instead compatibility with older wireless 2.4Ghz devices.
Try setting your CTS/RTS Threshold to 2347 to maximize compatibility with older wireless devices:
- Go to the web admin portal at http://orbilogin.com/
- Click to the Advanced tab, Advanced left menu, Wireless Settings
- Set CTS/RTS Threshold to 2347 for both 2.4hz and 5Ghz networks
- Press Apply
See if that helps. If problems still persist, next try disabling AX mode for the 2.4Ghz band:
- Go to http://orbilogin.com/
- Click to hte Advanced tab, Setup left menu, Wireless Setup
- Uncheck "Enable 2.4G" under the top Enable AX section
- Press Apply
Dec 07, 2021Guru - Experienced User
What is the distance between the TV and the RBR and RBS?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Disable AX mode on 2.4Ghz.
FYI:
- mbaltimoreDec 07, 2021Initiate
Firmware - 4.6.5.14
Spectrum ISP - Modem, DOCSIS 3.1 E31U2V1
Home - 5200 SqFt
Distance between router and sat is ~30Ft.
Distance between TV and Sat is ~15Ft.
Channels - Auto (2.4) and 48 (5)
- FURRYe38Dec 07, 2021Guru - Experienced User
Try turning OFF the RBS and see if the TV will connect to the RBR signal.
The other suggestions are something you can try on the RBR to help with getting the TV connected. You may need to seek some additional in person help to help you with this.
- Mikey94025Dec 07, 2021Hero
- Press Apply
- Press Apply
