Dashbord
Oct 07, 2023Guide
Orbi RBR750 only youtube.com problem
I have RBR750 and two satellites, from few days only youtube.com is buffering/lagging problem, i can play youtube video at 240p but still lagging at 240p, youtube works normal on apple and android de...
- Oct 09, 2023
I'd try your ISP modem back in router mode. Use it's DMZ for the RBR. Be sure any wifi radios on the ISP modem are disabled while it's in router mode.
Oct 07, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Are the Windows PCs wireless or ethernet connected to th Orbi system?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
Armor, Smart Parental Controls or Circle, Traffic Meter.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
MIght review information about newer FW version as well:
- DashbordOct 08, 2023Guide
I followed all your steps, upgraded firmware and reset everything according to your suggestions but still youtube.com lagging/buffering on Windows browsers. Everything is working normal except youtube.com and youtube apps on apple, samsung tv and on android working normal and no lagging. I have testet LAN and wireless and same problem on both. There is no signal problem, ever i sit near router or satellite youtube.com lagging/buffering on windows devices.
Already disabled Armor, Smart Parental Controls or Circle, Traffic Meter
Modem is on Bridge mode and the model is Zyxel EX5401
- FURRYe38Oct 08, 2023Guru - Experienced User
And does this still happen if you turn OFF all RBS and just wirelessly connect to the RBR alone?
Are speed test results using Ooklas installable speed test app on ethernet and wireless working to spec for the ISP speed you pay for UP and DOWN?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-messageSet 20/40Mhz Coexistence to 40Mhz only. Set CTS to 64. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.- DashbordOct 09, 2023Guide
I tried turn OFF all RBS and just wirelessly connect to the RBR alone, still same problem.
Speedtest in pictures. There is no signal problem in house, i have one router and 2 satellites and both are connected via cable, youutbe.com problem is from 2 weeks and before that everything was perfect every stream website and app is working normal, only problem is youtube.com, House is 7000 sq ft ,
