Dashbord
Oct 07, 2023Guide
Orbi RBR750 only youtube.com problem
I have RBR750 and two satellites, from few days only youtube.com is buffering/lagging problem, i can play youtube video at 240p but still lagging at 240p, youtube works normal on apple and android de...
- Oct 09, 2023
I'd try your ISP modem back in router mode. Use it's DMZ for the RBR. Be sure any wifi radios on the ISP modem are disabled while it's in router mode.
Oct 11, 2023Guru - Experienced User
So the ISP modem in router mode is work with the Orbi system OFF?
Dashbord
Oct 12, 2023Guide
Yes works in router mode, but it was on bridge mode and working great but only from 2 weeks there was a problem, now everything is working. Thanks:)
- FURRYe38Oct 12, 2023Guru - Experienced User
And did you put the Orbi system back online with the ISP modem in router mode? Try AP mode on the Orbi system and leave the ISP modem in router mode and disable it's wifi radios...
