chrisandy
Aug 13, 2022Aspirant
Orbi RBR750 Packet Loss
Model Number: RBR750 Firmware Version: V4.6.8.2 Hello, I have an Arris S33 that I just bought, connected via coax and connected to the RBR750 router - physically right next to it. I have ...
Aug 13, 2022Guru - Experienced User
Hello,
I have an Arris S33 that I just bought, connected via coax and connected to the RBR750 router - physically right next to it. It's recommended to have at least 6 feet in between the RBR and ISP modem.
What CAT# lan cable are you using? CAT6 is recommended.
I have several different devices connected to the RBR750: a PC, a PlayStation and an Xbox. Each of these devices is experiencing intermittent packet loss but the PC has been getting the brunt of it lately.
I was having this same issue on a Surfboard 8200 and a new modem was recommended, but no change.
I apologize for the vague question but what would be the next logical troubleshooting step?Use one wired PC and install pingplotter.com and test with the one wired PC connected to the ISP modem with out the RBR in the middle and check for packet loss and other issues between the PC, modem and ISP services.
- chrisandyAug 13, 2022Aspirant
I am using CAT6
I anecdotally tested (via gaming) and detected less packet loss when hard wired directly into the modem vs hard wired into the router. Currently running PingPlotter for 10m directly to modem then will do the same with the router. Still trying to figure out this software - am I able to share the results here?- CrimpOnAug 13, 2022Guru - Experienced User
I tend to make a screen shot and attach it to a post using the "Drag and drop here" feature at the bottom.
Are these devices connected
- Directly to the Orbi router with Ethernet cable?
- Directly to the router over WiFi?
- Connected to a satellite?
So there are three devices reporting packet loss: PC, PS5 and Xbox.
The PC and PS5 are connected directly to the Orbi via ethernet. The Xbox is connected via a hub that connects to the Orbi.
