DORAN033
Jun 18, 2023Aspirant
Orbi RBR750 Port Forwarding Issue
Hi there! I have been port forwarding some self hosted sites [using NPM] through my orbi router for about 6 months now, and suddenly it stopped working. As of a week ago, any time I go to the public ...
Jun 18, 2023Guru - Experienced User
Is uPnP disabled or enabled on the RBR? Should be disabled if you have any Port Forwarding configurations enabled.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
DORAN033
Hi again! I did the restart that you recommended. The issue is still the same issue and takes be right back to the orbi login page as always. Any other ideas? This is driving me slightly insane.
