DORAN033
Jun 18, 2023Aspirant
Orbi RBR750 Port Forwarding Issue
Hi there! I have been port forwarding some self hosted sites [using NPM] through my orbi router for about 6 months now, and suddenly it stopped working. As of a week ago, any time I go to the public ...
Jun 18, 2023Guru - Experienced User
Is uPnP disabled or enabled on the RBR? Should be disabled if you have any Port Forwarding configurations enabled.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
DORAN033
I also think uPNP is on. The setting "Turn UPnP On" is checked. Should I disable that?
