Fractious
Nov 18, 2022Follower
Orbi RBR750 Problem
Hi All, I have an Orbi RBR750 issue. Both the router and satellite are firmware v4.6.9.11_2.3.5 and are configured to backhaul traffic through a wired connection. My issue is that recently ...
Nov 18, 2022Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update?
Try enabling Guest Network, Set a new name for the network. Let the system apply the change. Then after the system is back, go back on disable GN...
