quaywe
Jun 21, 2022Tutor
Orbi RBR750 randomly disconnects/reboots, and loses config settings
My RBR750 randomly reboots 1-2 times per day (that I notice). This has been happening for around 6 months though seems to have gotten worse in the last 3 months. When this happens: I leave it...
Jun 21, 2022Guru - Experienced User
quaywe
Jun 21, 2022Tutor
Thanks. I finally figured out how to enable email logs today (app pwd) so will keep an eye on the uptime (and logs) from here.
FURRYe38 would it help us/you troubleshoot if we enabled debug logs and/or packet capture from the debug page? Those are pretty verbose so not sure how much is retained, what happens to them when memory full, etc. But thought I would ask.
Cheers
- FURRYe38Jun 22, 2022Guru - Experienced User
It's up to you. Were mostly checking to see if email logs help your RBR stave off these mysterious reboots that some of us see...
- quayweJun 26, 2022Tutor
Looking good!
System Uptime: 5 days 19:29:04
- FURRYe38Jun 26, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
