WAccountHolder
Oct 11, 2024Aspirant
Orbi RBR750 reboots everyday
I have the RBR750 Router with 2 satellites. Since last August, the router would reboot on a daily basis. The light on the router would turn purple, followed by white. I seen solutions on the web wh...
Oct 11, 2024Guru - Experienced User
Are you sure its rebooting? Usually when its magenta, its lost its ip address.
This tends to be because of a internet issues.
What modem/gateway is the router connected to?
- WAccountHolderOct 12, 2024Aspirant
Sorry I should not have used the word "reboot". However, I find it strange that the router losses internet connection everyday at about the same time, but it reconnects immediately. I would lose a few minutes of connection time. The issue could be with my internet provider (Spectrum), but I want to exhaust all avenues before contacting them. I do find it concerning that I can no longer access the admin login to the router.
- plemansOct 12, 2024Guru - Experienced User
what modem/gateway do you have from spectrum?
