Petergo
Jun 02, 2023Follower
Orbi RBR750 reports Sonos Play 3 blocked
Hi All I have been running an Orbi RBR750 router with 3 satellites for about 18 months providing WIFI around my property. Because it is connected into another router i am running the RBR750 in AP M...
Jun 02, 2023Guru - Experienced User
What happens if you turn OFF The RBS and connect just with the RBR only?
When in AP mode, Orbi should not be or would not be blocking anything as its just passing data from devices to the host router.
What FW is loaded on the system?
