mattybme
Mar 14, 2022Aspirant
Orbi RBR750 Router & 2 Satellites - One Satellite bearing the full load.
I had some troubles with my RBR 750 a week or so and support requested I flash the firmware and then perform a shock reset on the rotuer. This I performed and things seem to be working but I am seein...
Mar 14, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
- mattybmeMar 14, 2022Aspirant
Firmware version is Firmware: 4.6.5.14_2.9.54
Verizon Fios G3100 is the ISP and Router. Orbi Router in AP Mode.
I have not moved those satellites since the troubles began. One is about 50 ft from Router on same floor and the other is about 30 ft from Router one floor above.
Hmm we just lost internet and the Router updated the Wifi/Network name to Admin but with same password. Never seen that before. I am back up.
- FURRYe38Mar 14, 2022Guru - Experienced User
Does the front LED turn on PINK with this happens on the RBR?
Is the wifi disabled on the host ISP router?
When we had the outage blip this morning yep the ring on the Orbi router was pink/magenta.
Wifi is disabled on the Fios Router and Orbi Router is setup in AP Mode.
House sq footage is 2,848.
