mattybme
Mar 14, 2022Aspirant
Orbi RBR750 Router & 2 Satellites - One Satellite bearing the full load.
I had some troubles with my RBR 750 a week or so and support requested I flash the firmware and then perform a shock reset on the rotuer. This I performed and things seem to be working but I am seein...
mattybme
Firmware version is Firmware: 4.6.5.14_2.9.54
Verizon Fios G3100 is the ISP and Router. Orbi Router in AP Mode.
I have not moved those satellites since the troubles began. One is about 50 ft from Router on same floor and the other is about 30 ft from Router one floor above.
Hmm we just lost internet and the Router updated the Wifi/Network name to Admin but with same password. Never seen that before. I am back up.
Mar 14, 2022Guru - Experienced User
Does the front LED turn on PINK with this happens on the RBR?
Is the wifi disabled on the host ISP router?
- mattybmeMar 14, 2022Aspirant
When we had the outage blip this morning yep the ring on the Orbi router was pink/magenta.
Wifi is disabled on the Fios Router and Orbi Router is setup in AP Mode.
House sq footage is 2,848.
- FURRYe38Mar 14, 2022Guru - Experienced User
If you turn OFF the RBS and leave just the RBR running, does this still happen?
When you set up the RBR for AP mode, did you set Dynamic or set a Static IP address configuration on the RBR?
No Dynamic or Static IP set on the Orbi Router no. If I turn off both RBS the devices connect to the RBR.
