vdotmatrix
Jun 15, 2024Guide
Orbi RBR750 satelite update without ethernet
 I have an Orbi Mesh system RBR750 with two satellites. In the orbi app the are red in the device manager.  There RBR750's firmware is current but the two satellites have dashes where the firmware ver...
- Jun 17, 2024There we go. Yay. I'd disable the Auto Update feature to be sure the RBR doesn't get updated from NG. Under Advanced Tab/Advanced Settings/Wireless Settings Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
 Enjoy. 📡
vdotmatrix
Jun 15, 2024Guide
192.168.1.1
I arrived at a login but I could not login.
admin
password did not work
Jun 15, 2024Guru - Experienced User
The IP address would be different for the RBS if ethernet connected.
If there connected via ethernet and using there assigned IP address, log in may appear and admin and password should work if they don't sync. If they sync and have good signal, then use the same log in as you use on the RBR.
