vdotmatrix
Jun 15, 2024Guide
Orbi RBR750 satelite update without ethernet
 I have an Orbi Mesh system RBR750 with two satellites. In the orbi app the are red in the device manager.  There RBR750's firmware is current but the two satellites have dashes where the firmware ver...
- Jun 17, 2024There we go. Yay. I'd disable the Auto Update feature to be sure the RBR doesn't get updated from NG. Under Advanced Tab/Advanced Settings/Wireless Settings Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
 Enjoy. 📡
vdotmatrix
Jun 17, 2024Guide
OMG….THIS NIGHTMARE IS OVER… I HOPE. I reset everything, installed the old modem. and updated the router with the v4FW and it now sees everything.
Jun 17, 2024Guru - Experienced User
There we go. Yay.
Enjoy. 📡
- vdotmatrixJun 17, 2024GuideI can’t login to Orbi login to turn the auto update off when I go into the Orbi app. I have a Red Square that says something needs to be updated but I know better now. I think I really do need to get the new modem anyway because it’s still not working just right specially with the router light not being solid still troubleshooting.
