rwjacks2
Apr 16, 2025Tutor
Orbi RBR750 satellites not connecting to RBR750 router. Appear to be constantly rebooting??
My Orbi mesh network has been working great for 3 years. Recently none of my 3 satellites are connecting to the router. They appear to be rebooting. I get flashing white LED then solid blue for mi...
- Apr 17, 2025
There we are. RBS350s. So you have different RBS model and this would be the RBS650 series.
You'll need to get the 350 updated to v.31 here first:
Then you'll need to downgrade the RBR to same version afterwards to same version.
Then factory reset and setup from scratch and then disable auto update on the RBR to prevent it from updating to anything newer. As there is no v.15 FW yet available for the RBS350 series.
Apr 16, 2025Guru - Experienced User
What Firmware version is currently loaded? RBR and RBS should be on save FW version always.
How was FW updated on the system?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Does this happen with the RBS turned OFF?
What channel configurations are currently set on the router?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, IPv6, Smart Parental Controls or Circle, Traffic Meter.
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
rwjacks2
Apr 16, 2025Tutor
Router and all satellites are on FW version: V7.2.7.15_5.1.16
Initially FW was installed automatically. I manually installed previous version on router and then manually updated to current version (V7.2.7.15_5.1.16)
Modem is a Arris SURFboard 6910.
Home sq feet is 3300. No changes to any hardware or location of router or 3 satellites in past 2 years. No changes in wifi settings. Satellites are about 20-30 feet apart. All had blue LED connections to mesh. All 3 satellites are exhibiting the exact same behavior.
Right now I have moved one satellite within 20 feet of router and turned other two off. Have tried the power off sequence of network devices as suggested with no change in behvavior.
When I power up the sattelite I see it show up in Netgear web app in Attached Devices for one second and then is show it as Disconnected. IP address assigned is 192.168.1.250
Changes to 2.4Ghz and 5Ghz channel numbers had no impact.
