aarshare
Jan 17, 2025Aspirant
Orbi RBR750 Sattelites Offline After ISP switch
I switched to Fidium Fiber yesterday from Xfinity and since the switch the router is working fine but the satellites are detected but are offline. I’ve done hard restarts on the satellites as well as ...
Jan 17, 2025Guru - Experienced User
Is this same offline seen in the RBRs web page and Orbi app?
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed?
Turn off and unplug modem.
Turn on computers and rest of network.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
- aarshareJan 17, 2025AspirantThat was the sequence I followed. Firmware on the router is 7.2.6.31
Firmware on the sattelites are 6.3.8.5
The ISP is an Adtran SDX632v- FURRYe38Jan 17, 2025Guru - Experienced User
Are the RBS 750 series model satellites? or 350 model series?
FW between the RBS and RBR is not on same level and the FW needs to be at same level.
- aarshareJan 17, 2025AspirantThe sattelites are RBS760. They came with the router as a package. Everything worked fine for 2 years until the ISP switch yesterday.
