CarterJoshua84
May 27, 2022Aspirant
Orbi RBR750 Slow WiFi Speed
I was finally able to get fiber at my house I have a 1Gig set up and currently have Orbi RBR750 for the router and two RBS350 for satellites. My modem speed is getting to the router at 945. showing i...
CarterJoshua84
Thank you for the insight... Would switching out my Orbi AX4200 System for the new AXE11000 system make a difference? Would it even be worth the money?
May 27, 2022Guru - Experienced User
Thats not a questions I can answer. That system is significantly more expensive.
Are you needing more speed? Unless you're moving massive amounts of data, the system you have is quite capable. you only need 25-40mbps to stream 4k for example. If you're pulling 400 off the satellites, how much faster do you need to go?
