TAC57
Jul 20, 2021Aspirant
Orbi RBR750 Speed test vs Asus Mesh?
Might anyone give me any insight on the following? I was planning on updating my home network with the Orbi RBR750 WiFi 6 system. My existing system is two Asus routers setup in an AiMesh. I got t...
- Jul 21, 2021
FURRYe38Thanks for all your input in this issue. I ended up having to move my satellite around until I got the blue light on the front of the satellite for 90-180 seconds on reset to get a decent connection on the backhaul. I'm looking at 190 Mbps Wifi connection now which I'm pretty happy with. :-)
With issues like these I'm thinking the first step should be to move the router and satellite within about 30 feet line of sight and check the speed of the satellite. If that is maxed (same speed if connected directly to the router via CAT5 cable) then start to move the satellite towards the desired location. After moving every ten feet, or behind a new wall, then unplug the satellite to reboot and retest the WiFi speed.
I know there are alot of variable with these RF signals but I would have though the distance between, and what's between, would be a little more forgiving. I would have like to keep the router in the basement under the great room but I had to move it upstair into the far corner of the great room to get a good signal.
Thanks again for all your time and input.
Jul 20, 2021Guru - Experienced User
I don't think your posting are getting sensored rather possible too soon for posting or possible duplication though other have been able to quote my info asked for. If it continues i'll have a forum moderator check it out for you. Probably just a something simple is all.
TAC57
FURRYe38So I unplug the satellite and got 6 feet from the Orbi router and connect via 5GHz wifi and with speedtest I get a ping of 6ms, 195Mbps DL and 201Mbps UL. When connecting to the router via CAT6 cable I see 3ms ping, 195Mbps DL and 202Mbps upload.
When moving the satellite back to the location about 50 feet from the router I drop to 20Mbps DL and 24Mbps UL. In looking at the Orbi app on my phone it tells me my ThinkPad E590 is connected via 5GHz with a Link Rate of 780 Mbps! What's up with the Link Rate?
Logging into the router it's reporting the connection type to the satellite is 2.4GHz and the Backhaul Status is Good.
- FURRYe38Jul 21, 2021Guru - Experienced User
"Logging into the router it's reporting the connection type to the satellite is 2.4GHz and the Backhaul Status is Good." I would think the connection type should be at 5Ghz, not 2.4Ghz...Maybe the reason why speeds are low here.
- TAC57Jul 21, 2021Aspirant
Good to hear. Glad you got it working better.
Ya will be various items that can effect wifi and performances. Basements are not recommended places for the host wifi router though.
If it's working well for you, keep it where its at.
Enjoy. :smileywink:
