Moerax
Jul 17, 2021Initiate
Orbi RBR750 Stuck on Firmware V3.2.18.1_1.4.14
Greetings. First time posting here. Appreciate any help offered : ) I purchased an RBR750 from Costco (RBR750 + 2 RBS750). During some setup issues, Tech Support had me update the router and s...
Moerax
Awesome. Thank you for all the feedback and suggestions. Got the router and satelites updated.
Jul 17, 2021Guru - Experienced User
Glad you got it updated.
Be sure to save off a back up configuration to file for safe keeping. Saves tine if a reset is needed.
Enjoy. :smileywink:
