doughughes2011
Nov 04, 2021Aspirant
Orbi RBR750 Takes Forever to Load Admin Screen
I am having an issue where I cannot load the admin screen with my Orbi RBR750. First it takes forever to load anything, if it does at all. And if it does load, it is a mix of text hyperlinks and so...
CrimpOn
Nov 04, 2021Guru - Experienced User
doughughes2011 wrote:
I am having an issue where I cannot load the admin screen with my Orbi RBR750. First it takes forever to load anything, if it does at all. And if it does load, it is a mix of text hyperlinks and some icons like below. But for the most part if it does load properly it takes a very long tome to do anything. Any help here?
Firmware Version V4.6.3.16_2.0.51
Is this a combination cable modem/Orbi? i.e. the CBR750
https://www.netgear.com/images/datasheet/orbi/CBR750.pdf
Has the unit been configured already, or is this the initial setup?
- doughughes2011Nov 05, 2021Aspirant
This is not a combination modem/router and this has already been configured. Been using it for 6 months or so.
- CrimpOnNov 05, 2021Guru - Experienced User
This is very strange. I was not aware that the RBR750 main menu would include "Cable Connection" as a menu item.
My Orbi router takes about 5 seconds for the web Home Page to appear.
My old Orbi was like that but this one takes 20 to 30 seconds to get this far.
