Retired_Member
Oct 01, 2021Orbi RBR750 Teardown
Does anyone know how to remove the backplate to the RBK753S. I've been searching and can't find it anywhere online. TG
Oct 01, 2021Guru - Experienced User
I think there maybe some screws under the rubber feet on each side...
I've never taken one of these appart.
There a reason why your asking this?
Retired_Member
Oct 01, 2021Mine overheats and loses connection at 50mbps. I wanted to expose the heat sink and put a fan on it.
- FURRYe38Oct 01, 2021Guru - Experienced User
Best way i found to add forced air to any router, place a USB laptop cooler fan under the RBR. Works well.
How long have you had this unit?
- Retired_MemberOct 01, 2021
Had it about 11 months. The disconnecting is getting more and more frequent.
So you think this maybe heat related?
