Mgotela4
Sep 09, 2020Aspirant
Orbi RBR750: White light on all the time (Future request)
I recently purchased the Netgear Orbi RBR750 unit. Upon setting everything up I noticed the white light on the bottom of the front (just below "Orbi") was remaining on. Everything is working right,...
- Sep 09, 2020
Hi and thank you for your quick response.
I was actually able to figure this out, even though the netgear rep informed me incorrectly. You are correct, the light should be "off" per the owners manual. I decided to do a factory reset and go through the set up again on the router. This has fixed my issue and the light is now off on the router.
Thanks!Matt
Sep 09, 2020Guru - Experienced User
Acutally the front LED should be OFF during normal operations:
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
If its ON, there maybe a problem in the system.
- Mgotela4Sep 09, 2020Aspirant
Thanks!Matt
- FURRYe38Sep 10, 2020Guru - Experienced User
Enjoy.:smileywink:
