Mgotela4's avatar
Mgotela4
Orbi RBR750: White light on all the time (Future request)
I recently purchased the Netgear Orbi RBR750 unit.  Upon setting everything up I noticed the white light on the bottom of the front (just below "Orbi") was remaining on.  Everything is working right,...
  • Mgotela4's avatar
    Mgotela4
    Sep 09, 2020
    Hi and thank you for your quick response.
    I was actually able to figure this out, even though the netgear rep informed me incorrectly.  You are correct, the light should be "off" per the owners manual.  I decided to do a factory reset and go through the set up again on the router.  This has fixed my issue and the light is now off on the router.
    Thanks!
    Matt
