Mgotela4
Sep 09, 2020Aspirant
Orbi RBR750: White light on all the time (Future request)
I recently purchased the Netgear Orbi RBR750 unit. Upon setting everything up I noticed the white light on the bottom of the front (just below "Orbi") was remaining on. Everything is working right,...
- Sep 09, 2020
Hi and thank you for your quick response.
I was actually able to figure this out, even though the netgear rep informed me incorrectly. You are correct, the light should be "off" per the owners manual. I decided to do a factory reset and go through the set up again on the router. This has fixed my issue and the light is now off on the router.
Thanks!Matt
Mgotela4
Thanks!
Matt
Sep 10, 2020Guru - Experienced User
Enjoy.:smileywink:
