G4Net
Jan 15, 2022Aspirant
Orbi RBR750 Wifi Guestnetwork and VLAN.
Hi, Does anyone know how the Wifi Guestnetwork works in the Orbi sytem? Does it have its own VLAN ID or does it work another way? I recently installed a RBR750 Orbi router (AX4200) with two Satel...
Jan 15, 2022Guru - Experienced User
I don't beleive the Home version of Orbi will support your configuration needs.
You may want to look at Orb Pro for VLAN support on LAN to WAN configurations.
