G4Net
Jan 15, 2022Aspirant
Orbi RBR750 Wifi Guestnetwork and VLAN.
Hi, Does anyone know how the Wifi Guestnetwork works in the Orbi sytem? Does it have its own VLAN ID or does it work another way? I recently installed a RBR750 Orbi router (AX4200) with two Satel...
Jan 15, 2022Guru - Experienced User
You are correct CrimpOn, Home class Orbi don't have LAN to WAN VLAN support. I beliieve only the WAN to LAN support for this specififc ISP or iPTV devices that need it. I know there is some VLAN configurations on Orbi Pro which maybe what the OP needs to look into.
https://kb.netgear.com/000046302/What-is-an-Orbi-Pro-WiFi-System
https://kb.netgear.com/000062272/How-do-I-create-configure-and-assign-VLANs-on-my-Orbi-Pro-WiFi-6
https://kb.netgear.com/000053872/How-do-I-set-up-my-Orbi-Pro-WiFi-System-to-work-with-Insight
https://kb.netgear.com/000054793/How-do-I-configure-port-VLAN-IDs-for-switch-ports-in-Insight
- FURRYe38Jan 15, 2022Guru - Experienced User
Ya..well, your tring to use Pro or Business class configurations for a home environement. Something most average home users don't have a need for or experience to setup.
You can get a Orbi 9 series system. It has it's own wifi 2.4Ghz radio for IoT only devices...not cheap either.
