chris8a
Aug 27, 2021Aspirant
Orbi rbr750 wifi speed test slows down
Hey all, I have a RBR750 Orbi WiFi 6 Router AX4200 that has a slow wifi connection for videos. The google speed test on the router LAN connection (ethernet) shows 100/38 Mbs (great) - It is connecte...
Aug 28, 2021Guru - Experienced User
How are you speed testing? Orbi app or wired PC and web browser?
What devices are you speed testing with?
chris8a
Aug 28, 2021Aspirant
Firmware version: V4.6.3.7_2.0.49
Modem is Telstra technicolor TG799vac. When connecting my new Dell Laptop XPS-15 to the LAN port on this modem the speed test works well at 106/28.2 Mbs and the download speed does not slow down while testing.
Speed test with this website is:
- Go to Google.com.
- Search for internet speed test.
- Tap or click Run Speed Test.
(Google partners with Measurement Lab (M-Lab) to run this test.)
Orbi speed test was done over wifi using the same XPS-15 with LAN cable unplugged.
download starts at 80Mbs (good) then drops down to 3Mbs (bad) over approx 10-15 seconds
- FURRYe38Aug 28, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- chris8aSep 04, 2021Aspirant
Thanks for the suggestions Furrye38. I applied your point #2.
Still no improvement.
Strange thing is that it used to work just fine untill a few months ago i.e. it has always had the double Nat, and it made no difference to the speed. Something else has changed, but i'm not sure what....
The download speed starts off fine (80Mbs), then slows down to 4Mbs over a few seconds. So videos are a pain to watch, they stop & start.- FURRYe38Sep 04, 2021Guru - Experienced User
Try the Orbi in AP mode with option #3...
