Rob6805
Feb 27, 2023Tutor
Orbi RBR750 with RBS350 satellites
I bought this system from Amazon not really doing much research. My problem is that one of my RBS350 satellites (I have two) doesn't stay synced/connected. I believe it's due to it's location (it's...
Rob6805
Feb 27, 2023Tutor
Thank you for the reply.
My house is kinda broken up. The RBR750 router is in the main part of the house that is about 2,800 square feet. It works without issue in this area. The first RBS350 satellite is in an area we call the "mud room". I'd guess it's maybe 100ft away from the RBR750 and separated by only a interior wall . This first satellite has no issues staying connected. The second RBS350 is further away in a "bonus room" above the garage. It is about 200 feet away from the main router and 100ft away from the first RBS350 (I thought the satellites are supposed to daisy chain, correct?) separated by two exterior walls (line of site) and an elevation (above garage). This is the one that doesn't stay connected. I once moved it down to the garage level and it was even worse at that location. I was hoping that the RBS750 with it's longer range would do the trick.
Mar 06, 2023Guru - Experienced User
100Ft would be to far in distance.
- Rob6805Mar 06, 2023Tutor
Hello,
I may have exaggerated the 100 ft. The first sat works with no issues. It's the second one that is at the upper level above the garage that has troubles. I was told that the sat's are supposed to daisy chain? It this true? I ask because when I look at the network map on the Orbi app it shows both satellites connected in parallel to the router and not in series (daisy chain).
- FURRYe38Mar 06, 2023Guru - Experienced User
Yes they support daisy chain. It's how you place them out in a line and then turn them ON in order will get the RBS to daisy chain.
Hmm, ok. I may have to look into this because I don't think they are daisy chained currently. I think the furthest one is trying to link to the main router and not the other sat.
