Smam_berg
Aug 08, 2021Aspirant
Orbi RBR750
How do I get the orbi app to detect my orbi network? I have tried all the suggested "still having issues?" I am connected to it via WiFi so I don't get why it's not detecting.
Smam_berg
Aug 09, 2021Aspirant
It’s an orbi RBR750. Trying to log into the iOS app. While on the Wi-Fi network. Says that network could not be detected.
michaelkenward
Aug 09, 2021Guru - Experienced User
Still not much wiser. That is the exact wording of the message that the Orbi App throws up?
Can you get into the RBR750 using the browser graphical user interface (GUI)?
That would rule out iOS issues. There have been problems with that in the past.
- Smam_bergAug 09, 2021AspirantSorry I’m not more clear on the issue. Maybe this photo will help a little. I will also try the GUI method and see.
- michaelkenwardAug 09, 2021Guru - Experienced User
Smam_berg wrote:
Sorry I’m not more clear on the issue. Maybe this photo will help a little.That's good. Now we can see what you are talking about.
Have you investigated setting up Anywhere Access? That will also work on your local network. It just gets there via the Netgear Cloud service.
Smam_berg wrote:
I will also try the GUI method and see.To be honest, that really is the best option for local management. Apps are designed to make like "east" whereas in reality they can be more trouble than they are worth.
I should have asked before, is there a modem of some sort in front of your Orbi? If so, what is it?
