ricci1
Mar 18, 2023Tutor
Orbi RBR750
I have an RBR750 and 3 satellites RBS750 in my system. The first question is I see a new firmware for my router when I go in to Administration -> firmware update . The satellites say no new firmware ...
Mar 18, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
Its highly recommended to manually update the RBS first using the RBS web page to send the FW file to each RBS. Then update the RBR lastly using the manual tab on the FW update page on the RBR.
ricci1
Mar 18, 2023Tutor
Hello FURRYe38
Appreciate the response.
Current firmware is V4.6.9.11 for both RBR and RBS
The ONT is DZS 2424GN - fiber optic to CAT6 to the Orbi RBR 750 about 40 feet away
Home size is 4,600 > Keep in mind I have two stories and one of the RBS is outside on a protective enclosure ( weather resistant ) to provide signal outside.
Distance between the router and satellites is about 60 feet for each one.
Copy on updating the RBS first followed by RBR. My question is should there be two different downloads ? One for RBS and one for RBR ? Where can I located them? I found this on the Netgear web page RBR750 (Orbi Router) Firmware Version 4.6.14.3 but no reference to RBS ?
- FURRYe38Mar 18, 2023Guru - Experienced User
Yes there will be separate FW files for the RBR and RBS:
