musiclover360
Aug 07, 2023Aspirant
ORBI RBR750
My download speeds is only 65MBs but my upload is 495mbs. MY Internet provide has a download speed of over 500mbs for me when I log into my ISP and run speed test. But when I log into the Orbi is 6...
Aug 07, 2023Guru - Experienced User
How are you speed testing? Wireless or wired ethernet?
What devices are you speed testing with?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How many RBS are deployed?
Armor, Smart Parental Controls or Circle, Traffic Meter.
- musiclover360Aug 07, 2023Aspirant
Orbi Firmware is V4.6.14.3_2.3.12
I have two satellites plus the router
Testing from iPad and from Laptop over wifi
I'll turn of Traffic Meter and see if that makes a difference
- FURRYe38Aug 07, 2023Guru - Experienced User
As a quick test, turn OFF the RBS and run speed test with your devices say 10 feet away from the RBR.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️- musiclover360Aug 07, 2023Aspirant
I'll check on the verizon gear... The home is 2900 sq feet and it's over 30 feet from Sat 1 to sat 2. It's under 30 ft from the router to Sat 1 (that distance is more like 15 ft
