NovTango
Sep 20, 2024Aspirant
Orbi RBR750
Hello. I’m trying to ##Unregister a product. I have done it on the website but when it’s added to the Orbi app it says it is still registered. 🤷♂️🤦♂ I have the serial number and device inf...
CrimpOn
Sep 20, 2024Guru - Experienced User
So, this device previously was registered to your account, and now when you log into the My Netgear web site and display the products registered to you, this device no longer appears?
Just a bit puzzled. What would be the point of unregistering a device and then attempting to add it to the Orbi app?
NovTango
Yes I unreegistered on the NETGEAR site per the Unregister instructions. The person I gave the RBR750 to is unable to register it for use with the app as it still shows as registered
- CrimpOnSep 20, 2024Guru - Experienced User
Bugger. Might be time to delete the Orbi 'app' from every device it has been installed on.
- NovTangoSep 20, 2024Aspirant
Thanks and Yes. I tried that as well. I’ll contact support…. Just wasn’t sure if there was a workaround…. Sounds like this may be a know issue in scouting the forums 🤔🤷♂️🤦♂️
