NovTango
Sep 20, 2024Aspirant
Orbi RBR750
Hello. I’m trying to ##Unregister a product. I have done it on the website but when it’s added to the Orbi app it says it is still registered. 🤷♂️🤦♂ I have the serial number and device inf...
NovTango
Yes I unreegistered on the NETGEAR site per the Unregister instructions. The person I gave the RBR750 to is unable to register it for use with the app as it still shows as registered
CrimpOn
Sep 20, 2024Guru - Experienced User
Bugger. Might be time to delete the Orbi 'app' from every device it has been installed on.
- NovTangoSep 20, 2024Aspirant
Thanks and Yes. I tried that as well. I’ll contact support…. Just wasn’t sure if there was a workaround…. Sounds like this may be a know issue in scouting the forums 🤔🤷♂️🤦♂️
