WhistlerNG
Feb 02, 2025Aspirant
Orbi RBR750/RBS350 x Yale Door Lock connectivity x IoT Compatibility
I've got an RBR750 and two RBS350 satellites. Both are on firmware v4 (so the RBS350s can still function properly with the RBR750). Most of our smart devices are able to connect via the guest network...
- Feb 02, 2025
v7 FW is now available for both RBR and RBS.
Update the RBS first then RBR lastly.
Feb 02, 2025Guru - Experienced User
- WhistlerNGFeb 02, 2025AspirantThanks for the reply. As I look at the netgear download center, the RBS350’s most updated firmware is v4. I’m not sure that v7 is out for my satellite. If it is, would love your advice for where to find that.
- FURRYe38Feb 02, 2025Guru - Experienced User
