WhistlerNG's avatar
WhistlerNG
Orbi RBR750/RBS350 x Yale Door Lock connectivity x IoT Compatibility
I've got an RBR750 and two RBS350 satellites. Both are on firmware v4 (so the RBS350s can still function properly with the RBR750). Most of our smart devices are able to connect via the guest network...
  • FURRYe38's avatar
    Feb 02, 2025
    v7 FW is now available for both RBR and RBS.
    Update the RBS first then RBR lastly.
