mariva
Jan 09, 2021Aspirant
Orbi RBR752 Mesh, Guestlan, SSH, VPN Client
Hi I bought the Orbi Mesh Set RBR750 couple days ago. Orbi™ AX4200 (RBK752) Tri-band WiFi 6 Mesh System I was talking with 2 different support members from netgear to precheck if my desired funk...
Feb 01, 2021Guru - Experienced User
Any updates on this?
- marivaFeb 02, 2021Aspirant
The be honest, the Netgear support is really bad. no technical know how or maybe just enough for 08/15 consumer. im super disappointed for such high-price models.
my solution: i switched to TP Link Accespoints with Omada Software. and Raspberry 4 with OpenWRT as Router.
I solved all my "problems" without stress. create community and support on both device/software.
the only disadvantage i have no wifi 6, tbh i dont need it, it would be a nice to have.
greetings.
- FURRYe38Feb 02, 2021Guru - Experienced User
Good Luck.
