mariva
Jan 09, 2021Aspirant
Orbi RBR752 Mesh, Guestlan, SSH, VPN Client
Hi I bought the Orbi Mesh Set RBR750 couple days ago. Orbi™ AX4200 (RBK752) Tri-band WiFi 6 Mesh System I was talking with 2 different support members from netgear to precheck if my desired funk...
mariva
Feb 02, 2021Aspirant
The be honest, the Netgear support is really bad. no technical know how or maybe just enough for 08/15 consumer. im super disappointed for such high-price models.
my solution: i switched to TP Link Accespoints with Omada Software. and Raspberry 4 with OpenWRT as Router.
I solved all my "problems" without stress. create community and support on both device/software.
the only disadvantage i have no wifi 6, tbh i dont need it, it would be a nice to have.
greetings.
Feb 02, 2021Guru - Experienced User
Good Luck.
