KevTheGutman
Oct 14, 2021Aspirant
Orbi RBR752 unstable internet, notifications come in batches
I have an Orbi mesh at home (AX4200) with the router and one satellite. I use the Netgear CM1200 cable modem. I'm on the Xfinity 1.2gbps plan, but the CM1200 limits me to 1gbps. The speed test on the...
Oct 14, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
KevTheGutman
FYI, update was performed this morning. I'll still do the power off.
FURRYe38 wrote:Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
- FURRYe38Oct 14, 2021Guru - Experienced User
đ
I would change custome DNS back to Auto and see if you notice any changes as well.
