KevTheGutman
Oct 14, 2021Aspirant
Orbi RBR752 unstable internet, notifications come in batches
I have an Orbi mesh at home (AX4200) with the router and one satellite. I use the Netgear CM1200 cable modem. I'm on the Xfinity 1.2gbps plan, but the CM1200 limits me to 1gbps. The speed test on the...
Oct 14, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
KevTheGutman
I've turned off the router and satellite, and then the modem. As soon as the router was turned off, I got flooded with notifications from ESPN, Reddit, LinkedIn, Discord, and more. I brought up the modem first, and waited for all appropriate lights to turn solid green. Then I brought up the router, and then the satellite. I'll report back if I see any differences.
