GG12345
Nov 29, 2024Aspirant
Orbi RBR760 - No Internet after ISP Change
Hello NetGear Community, I am in need of assistance and I know this is the right place. My Orbi RBR760 has been running without any issues until this. I switched my ISP from Rogers to Bell...
Nov 29, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
My Orbi RBR760 has been running without any issues until this. I switched my ISP from Rogers to Bell and noticed the Orbi mesh network was down. I tried the following after:
1. Setting up the network by following instructions for new ISP2. Hard reset (holding reset in the back) to restore to factory settings and following the setup instructions.
However every time I go through the steps the Orbi Router is unable to connect to the internet (tried hard reset 5 times). I called the support line and they told me that the router had locked because of the IP change. But for them to help they need me to send them payment for the security plan. Just frustrating that they are able to help but wont unless I send them $200-$300...
Could someone in NetGear community help me please!!
Thank you!!
- GG12345Dec 22, 2024Aspirant
It is a Bell Modem - Giga Hub P/N - 253960552
Yes, I have tried a few different cables now. Still no luck. Also tried on a different modem and no luck.
Thank you for the instructions, but even after all this no luck either. I tried to take it to a Geek Squad Tech and they were no help either....their networks are protected so they cant even try to connect.- FURRYe38Dec 23, 2024Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
