GG12345
Nov 29, 2024Aspirant
Orbi RBR760 - No Internet after ISP Change
Hello NetGear Community, I am in need of assistance and I know this is the right place. My Orbi RBR760 has been running without any issues until this. I switched my ISP from Rogers to Bell...
GG12345
Dec 22, 2024Aspirant
It is a Bell Modem - Giga Hub P/N - 253960552
Yes, I have tried a few different cables now. Still no luck. Also tried on a different modem and no luck.
Thank you for the instructions, but even after all this no luck either. I tried to take it to a Geek Squad Tech and they were no help either....their networks are protected so they cant even try to connect.
Dec 23, 2024Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
