DavidofHants
Jan 02, 2025Follower
Orbi RBR760 and Google Nest Hubs
I wanted to set up the hub using the Guest network which is impossible without disabling the AP Isolation. However there is nowhere that I can see that enables this. Has it been permanently enabled on the guest network?
1 Reply
GN is always isolated on Orbi systems for security reasons.
Guest Network is a transitory network and not really meant for long term device usage.
