Aved590
Dec 24, 2022Aspirant
Orbi RBR760, guest network, giving improper IP and subnet
I recently bought and installed from Costco the Orbi RBR760 (router) and 2 RBS760 (satellite). It's running firmware version V6.3.6.4_1.2.68. Guest network setup and running without issue fo...
- Dec 27, 2022
Problem resolved.
I had Orbi cancel the "Parental control" feature. This gave me back the "Access Control" section on the web administration page. Once I turned off all the Access Control, the problem went away. Now I need to learn a bit more on how Orbi's access control works.
Aved590
Additional info: I'm running the router as a router, not using AP mode. I have Verizon FIOS and a direct Ethernet connection from the ONT.
