Aved590
Dec 24, 2022Aspirant
Orbi RBR760, guest network, giving improper IP and subnet
I recently bought and installed from Costco the Orbi RBR760 (router) and 2 RBS760 (satellite). It's running firmware version V6.3.6.4_1.2.68. Guest network setup and running without issue fo...
- Dec 27, 2022
Problem resolved.
I had Orbi cancel the "Parental control" feature. This gave me back the "Access Control" section on the web administration page. Once I turned off all the Access Control, the problem went away. Now I need to learn a bit more on how Orbi's access control works.
Aved590
Excellent information! I didn't know about Link Local Address.
Now to turn off the Access Control. I enabled Parental Controls for thee trial period. I found its more trouble than it's worth. I have requested customer service to turn it off since it's only controlled through the app now. I tried to get rid of all profiles and make sure everything has full access but my devices still aren't happy on the guest network. I'll keep messing with it.
Thanks again for your help and getting me on a potential track to a solution.
Scott
Aved590
Dec 27, 2022Aspirant
Problem resolved.
- FURRYe38Dec 27, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
