ckon9's avatar
ckon9
Follower
Oct 30, 2023
Orbi RBR840 stopped connecting to internet
We have Cox as our ISP. We have started having internet issues over the past month. Our initial setup was cox compatible personal modem and my Orbi RBR840 mesh system. I had never had any issues with this setup before.
1st issue: our internet went out. After many days I was told our modem was “old”. Even though the specifications were better than what the other options were and it had be working just fine. So I bought a new modem that was on their list from Walmart.
This worked for 24 hrs then stopped working.
Another few days passed bc I thought out outside cable line had be cut due to landscape work.
The ISP came out and everything was fine with the wire.
For there I got a modem directly from cox and connected it to my Orbi… still no internet connection.
I then just went and got the Cox Panoramic Gateway and used it as the modem and router. It works just fine. But I really am missing the coverage that the Orbi mesh provided to our property.
So I tried putting the Cox panoramic gateway into bridge mode and using the Orbi. Still no internet! I even did a factory reset of the Orbi. https://www.reddit.com/r/orbi/comments/17kb0ir/orbi_rbr840_stopped_connecting_to_internet/?utm_source=share&utm_medium=web2x&context=3
Any help?!?
1 Reply
